584,861 active members*
5,138 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > hurco ultimax 2 bmc 40
Results 1 to 16 of 16
    Aug 2014
    8
    i have a problem when jogging the machine the number go to ******** the back to number i change the dual axis board and still same problem
    then i change the dallas erom on the memory card thinking maybe the problem is from it and now the machine do not start
    i got a new memory car with same version v7.24 but with battery and same problem n the start up
    Jun 2008
    1103
    Re: hurco ultimax 2 bmc 40
    Post up a pic of the switches on the memory board please.
    Aug 2014
    8
    Attachment 247408Attachment 247410Attachment 247412Attachment 247412Click image for larger version.
    you will find also the alarm lamp shown in picture
    Jun 2008
    1103
    The switches look OK. Is the machine you are using this in an MD1 like the labels say? You can only use software that is specific to the machine it is being put in due to different I/O being used. When your old memory board stopped working, was it just after you pulled the dual axis card?
    If you put your original memory board back in but leave the dual axis boards out, does it start up but very slow?
    Is it just starting up to a cursor in the bottom left corner of the text display?
    Aug 2014
    8
    Attachment 247456Attachment 247458Attachment 247460
    this picture is the old memory card I will test now and let you know
    Jun 2008
    1103
    The old memory board is for a BMC20 - 50 and the new one is for an MD1.
    If you swap the EPROMs U65 through to U76 from your old board to the new one, it will be compatible.
    Also, your 3D option is held in U75 & U76. The new ones don't have 3D.
    Aug 2014
    8
    first I try the old memory card without the dual axis board and is the same no replya at all
    second I swap the u 65 to u 76 from the old memory to the new one with and without dual axis board same thing no reply at all
    and all the time I have the second red lamp on in the new memory board
    the power supply is ok
    Jun 2008
    1103
    Put the U65 - U76 back into your old memory board and swap Dallas chips 1&2 with 3&4 to see if it will start. Also, remove and re-insert the Personality card.
    Jun 2008
    1103
    Any part programs you have are in the Dallas rams and are probably lost or corrupted. You can sometimes get round the corruption by swapping them in pairs.
    Aug 2014
    8
    if I got 4 new dallas and I installed them there any proceed I must to do
    Jun 2008
    1103
    No, try the old ones again.
    Aug 2014
    8
    I ma still have the problem I found 2 think 1 the led on the personal board is off
    and the second is a condenser burn in the rack (can you think can do something
    I have a friend with a really old hurco with the Dallas chips. I figured out it the batteries of these chips gone dead. so i replaced them with new DS1230Y-150 chips. The machine was booting up right except when changing tools or wanting to make a new programm it hang up on me.After replacing the chips the machine just boots into a flashing cursor on the bottom left side of my left monitor.Going back to the old chips it did not work either. Now I am stuck with the flashing cursor in both cases old and new chips. the flashing cursor is mentioned here so i believe you can have a solution for this?
    ok when pulling out the personality board it boots up slowly as said. reinserting it brings me back the blinking cursor
    figured it out. problem was in the dip switches on the personality board
    Jan 2019
    4
    I have the problem with my HURCO BMC40, ULTIMAX II, When machine is power up, screen displays
    " Machine config defaults have been loaded and must be verified or reset before continuing"
    The values all seem to correspond to the travels of my machine in the manual and I can scroll through with the enter or advance keys and back with the back key,I can re-type the values but not get off the screen.
    If anyone have rectified the same problem or have info then share please
    Any suggestions?[/QUOTE]
  1. Hurco BMC 30 SSM Ultimax 3
    By CNC-Germany in forum HURCO
    Last Post: 01-13-2013, 03:15 PM
  2. Hurco Ultimax II
    By gregm1976 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 08:11 AM
  3. Hurco BMC 20 - Ultimax 3
    By arvishal in forum HURCO
    Last Post: 10-03-2008, 08:57 PM
  4. Ultimax 3 for Hurco
    By Nong Noy in forum Post Processors for MC
    Last Post: 08-16-2008, 04:02 PM
  5. Hurco KM3 w/ Ultimax
    By Mr. LocoMartin in forum HURCO
    Last Post: 01-14-2008, 03:18 PM
