585,932 active members*
3,757 visitors online*
    Apr 2005
    52
    Hurco VMX30 Help
    Hi all, I have to go to a shop tommorow and set up and run a job on a hurco vmx30 and I know how to use g-code but not the conversational, how do I change over to g-code and how will I be able to set g54, hight and d offsets?. .The programming and machinig side is no problem I at the moment use kitamura and matsura and been in the bussness for 30 years, the Hurco is a new one to me.
    Thanks in advance.
    Forrey.
    Feb 2006
    103
    Im sure if the shop has the manual for the machine it will clearly state the operations in there, like work and height offsets etc..
