586,009 active members*
4,952 visitors online*
Results 1 to 7 of 7
    Aug 2014
    11
    New laser cutter - Not cutting straight
    Hi, i'm completely new to the forum/ laser cutting thing so i'm sorry if i actually know very little. We recently got a LC1390 with a 150W tube, and after aligning the mirrors, and all the stuff you are supposed to do (also the platform was unleveled, we worked that out). So, everything seems to be in order but we have been cutting just circles and squares, and all of them come with imperfections on the edges. Basicaly all of them are not 100% straight, with no apparent pattern. The pictures can show that. This is 15mm MDF.
    Attachment 247356Attachment 247358Attachment 247360Attachment 247362
    What should i do / check for?
    Thank you all in advance
    Feb 2012
    387
    Re: New laser cutter - Not cutting straight
    Hi Rjavier,
    is your machine leetro system or RDCAM system?
    Quote Originally Posted by rjavier View Post
    Lucy Lee G.WEIKE LASER
    [email protected]
    Aug 2014
    11
    Quote Originally Posted by gweikelaser View Post
    Hi Rjavier,
    Leetro i think, it uses lasercut 5.3.
    Sep 2012
    212
    Beam alignment problem
    G.Weike Laser
    [email protected] [email protected] skype:melody.gweike
    here's a trouble shooting lesson may help you:
    Why engraving edge out-of-straight
    good luck.
    www.thunderlaser.com
    Aug 2014
    11
    Thanks for the link and indications. I've read them and done what i can so far.
    So, after realigning and checking things, the problem is still there. I made this diagram to explain a little better why i do not think is the beam alignment. Attachment 250468
    Basically, doesn't matter where on the table i cut this square, the left side of it it's always uneven. And all of the others sides look very straight.
    Thanks again!
    the problem happen in your last step in beam alignment
    laser pass through third reflect and focus
    belowing is video link on our website to teach you how to adjust the laser path
    http://www.wklaser.com/vid_59.aspx
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
  1. cutting 3mm acrylic by laser cutter
    By Nolan Yang in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-23-2014, 09:26 AM
  2. cutting paper by laser cutter
    Last Post: 07-16-2014, 04:14 AM
  3. Laser cutter nog cutting smooth
    By NatD in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-01-2014, 03:05 PM
  4. laser vector cutting, not straight, wavy instead
    By megadice in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-07-2014, 12:21 PM
  5. Laser Cutting Engraving Machine Laser Cutter 1400*900mm
    By cnc_laser in forum Commercial Laser
    Last Post: 07-10-2013, 08:52 AM
