Yes, it may be a system/software/CMOS crash. The BMDC counts down to ZERO when it cannot load. Typically, you can remove the BMDC carefully and clean the edge connector with a soft eraser, and plug it back into the same ISA slot or a different one. I have also seen GENERAL PROTECTION faults with flaky power suppies, overheating processor, or memory getting flaky. If you can get to DOS, type in DATE and see how far off it is. Way off means the CMOS settings may be way off too.
George
