585,578 active members*
3,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA VAC III ALARM 25 help
Results 1 to 6 of 6
    Aug 2012
    4
    Exclamation OKUMA VAC III ALARM 25 help
    Hello;
    l have OKUMA VAC III spindel driver, thr is alarm 25,cpu led on,M1 on,M2 on,4.green led on.
    İs thr anybody know tht alarm?
    [email protected]
    Aug 2011
    419
    Re: OKUMA VAC III ALARM 25 help
    Drive units kitabını ekledim. Sayfa 79'a bak. Problem power supply olabilir.
    Attached Thumbnails Attached Thumbnails VAC_II_III_Maintenance_Manual.pdf
    Aug 2012
    4
    daha önce bu arızayla karşılaştınızmı?
    referans gerilimleri +5 ve +15 normal gözüküyor.
    Dec 2014
    okuma cnc lathe 1783-01 alarm-a turret unclamp time over a side 2
    Aug 2011
    419
    1783 Turret unclamp time over
    Unclamp operation is disabled or takes time.
    [Object]
    AXIS
    [Code]
    1->Turret unclamp confirmation switch is not ON.
    2->TA axis clutch connect confirmation switch is not ON.
    3->B axis brake OFF confirmaition switch is not ON.
    [Probable Faulty Locations]
    1)Maladjustment of the unclamp limit switch
    2)Low oil pressure
    3)Malfunction of the solenoid valve
    4)Malfunction of B axis brake
    OKUMA VAC III spindle driver, alarm 25 is a "Cycle over error" show a problem with your VAC top board
    It shows the CPU circuit has a malfunction problem and stops functioning and all lights go to on position but is repairable.
    Barry
    CNCOpenSolutions.com
  1. Okuma Alarm
    By andreibitza in forum Okuma
    Last Post: 07-25-2014, 10:46 PM
  2. Okuma LB 25 SDU Alarm
    By yc00146 in forum Okuma
    Last Post: 09-30-2012, 10:22 PM
  3. OKUMA ALARM
    By okuma_sos in forum Okuma
    Last Post: 06-24-2011, 04:16 AM
  4. Okuma MV-5A VAC ALARM
    By actarus69 in forum Community Club House
    Last Post: 09-04-2009, 03:05 AM
