585,977 active members*
4,244 visitors online*
Results 1 to 9 of 9
    Jul 2014
    19
    Angry beam alignment
    Hi there,
    I'd like to share some frustration.
    Here's the problem: can't get my beam alignment in the center of the mirrors.
    Need some advice, it's cracking my brain.
    The beam always ends up way to high in the mirror.
    Attachment 247532
    Any alignment experts on this forum?
    Best regards,
    MArk
    Jul 2014
    19
    Re: beam alignment
    Ok,
    so I lowered the tube, I lowered the first mirror.
    But I do keep ending up to high in the second mirror.
    There must be something wrong with my adjusting technique...
    Nov 2008
    382
    Re: beam alignment
    hi there
    we need to know what machine you got and a few picture
    greetings
    waltfl
    May 2010
    41
    Re: beam alignment
    Take some photos of the mirror and the mount that the mirror is attached to.
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
    Re: beam alignment
    Quote Originally Posted by LaserMark View Post
    Hi there,
    Attachment 247532
    Best regards,
    MArk
    Hi Mark
    here's a video to guide you how to align the laser beam:
    https://www.youtube.com/watch?v=pw8Ro2vEEzY
    hope it can help you.
    www.thunderlaser.com
    Jul 2014
    19
    Re: beam alignment
    So far I ended up with my little hacksaw to make the tube mounts a little shorter...
    I did an alignment of the first two mirrors and the tube with a laser-leveller.
    Now everything seems fine. The machine is running and I'll take some pictures when the job is done...
    pff huge effort to get this done!
    Nov 2008
    382
    Re: beam alignment
    hi
    you need to alligne all the mirrors with the laserbeam or it will not bring you max cutting power.
    greetings
    waltfl
    Jul 2014
    19
    Re: beam alignment
    Attachment 248068
    I alligned the mirror, with the beam and the second mirror.
    All in the same plane. The beam hits the first mirror at the center spot!
    Nov 2008
    382
    Re: beam alignment
    ok now you need to adjust this mirror ( #1) with the three screws that the beam hits the second mirror dead center if you move the X axis to the front ( closest to the tube)and the back . that's a bit fiddeling the first time.
    then you need to adjust the third mirror that the beam hits dead center her too in all four corners of you workarea.
    don't be discouraged it takes a long time the first time till you know which screw brings up what.
    greetings
    waltfl
  1. Replies: 32
    Last Post: 11-22-2015, 11:16 PM
  2. Looking for an experienced tech in laser beam alignment preferably in Melbourne.
    By ozstockman in forum Australia, New Zealand Club House
    Last Post: 07-27-2013, 07:36 AM
  3. Beam alignment prodedure Laserpro Explorer
    By edutech in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-14-2012, 06:37 PM
  4. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
