Here's some videos of my software running the Taig Micro Mill around. I wanted to make it really easy to make things with machine tools.
With SuperCamXp you can move your computer controlled routers, milling cutters and plasma torches around with a point and click of the mouse and it’s position will be shown on the screen. You can import DXF files and the attached machine will follow the lines in the drawings at the set depth of cut or incrementally cut to the Final Cut depth. The Feedrate is set by slide bar controls.
It works with a USB to parallel port connector adapter board that has a microprocessor on it to generate the step and direction signals.
Here is page with some videos.
Super Tech's You Tube Video Gallery
