585,683 active members*
4,974 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > 4th axis jewelry carving
    Jul 2011
    15
    I'm trying to generate a toolpath to make a ring on my rotary 4th axis.
    Roughing with a 1/8" bit is fine but the problem is that Its taking way too long to generate the finishing path for the bits that i use.
    I have 2 bits that i want to use for finishing. 0.3mm endmill and a 1/8" veemill / v-bit.
    Could someone help me get around this problem?
    Jul 2011
    15
    Re: 4th axis jewelry carving
    After a week of continuous research I found that jewelers use .004 stepover when using a tapered bit. I've successfully milled a ring with those specs but it took about 5hours to calculate the toolpath. Is it normal for Rhinocam to take that long to calculate the toolpath?
  1. V26 4 Axis Carving a statue
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-11-2014, 10:43 PM
  2. Jewelry with CNC
    By ashyl in forum News Announcements
    Last Post: 08-12-2010, 10:20 PM
  3. Heavy large scale gantry mill/router/3d carving 5 axis build
    By Tristar500 in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 12:07 PM
  4. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
  5. Carving machine,Design question? about z axis
    By hkxy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-11-2006, 09:43 AM
