Quick Details
Application: Laser Cutting Condition: New Laser Type: Fiber Laser
Applicable Material: Metal Cutting Thickness: 16mm Cutting Area: 3000mm*1500/2500*1300mm
Cutting Speed: 80m/min CNC or Not: Yes Cooling Mode: Water Cooling
Control Software: PA8000 Graphic Format Supported: AI,PLT,DXF,DWG,DXP,NC PRT Place of Origin: Hubei China (Mainland)
Brand Name: GN Laser Model Number: GN-CF3015-1000W Certification: CE
After-sales Service Provided: Engineers available to service machinery overseas Color: Custmize Funtion: Metal cutting
Type: Fiber Laser Weight: 6000KG Laser Source: IPG Fiber Laser
Driving System: TBI Ball Screw from Taiwan Min Cutting Kerf: 0.1mm Max Cutting Thickness: 16mm
No Performance index parameter Note
1 Cutting area(length×width) 3000mm×1500mm
2 X axis route 3000mm
3 Y axis route 1500mm
4 Z axis route 120mm
5 X/Y axis positioning accuracy 0.03mm/m
6 X/Y axis positioning accuracy +0.01mm
7 Maximum speed 80m/min
8 Maximum acceleration 0.5G
9 Machine weight 3000Kg
10 CNC system Weihong
11 Workbench maximum load 500kg
12 Number of phase 3
13 Power rated voltage 380V
14 Frequency 50Hz
15 Total power protection grade IP54
Features
1. Cutting head:Laser mech; Servo Motor:Panasonic; Driving System:Taiwan TBI ball screw
2. Most cost-effective laser cutting machine compared with Fiber laser machine and CO2 laser machine
3. High accuracy, meeting demands for cutting nearly all kinds of plate metals
4. Auto-tracking system for focus length, keeping a constant distance with material and cutting nozzle
5. Low running cost, air is qualified to be auxiliary gas for cutting all material
6. Dust-removing system is installed
7. Gantry typed designed, compact structure to minimize the floor area
8. imported Optical components,superior laser beam and high electric-optic conversion ratio
Samples for reference
http://www.gnlaser.com/?fpage/l2/c000347|000421
Video for reference
1mm copper cutting. Wmv: Http: //goo. Gl/hQG7Y
1mm stainless steel cutting. WMV: Http: //goo. Gl/NVAJ1
3.5mm stainless steel cutting. Wmv: Http: //goo. Gl/GBE1U
4mm carbon steel cutting. Wmv: Http: //goo. Gl/iFUYC
1mm aluminum cutting01. WMV: Http: //goo. Gl/eFi9A
1mm aluminum cutting 02. WMV: Http: //goo. Gl/BOzq5
2mm aluminum cutting. WMV: Http: //goo. Gl/h3OzU
Applicable Materials
Stainless steel, carbon steel, alloy steel, silicon steel, spring steel, aluminum, aluminum alloy, galvanized sheet and other metal pipes and tubes
Applicable Industry
industrial pipeline processing, explosion-proof equipment, military industry, chemical industry, oil exploration, lamps and lanterns, metal processing, ironware, building, etc.
Pre-sale Service
1.Sample testing: We will supply testing report with video and photos upon you request.
2.Customized machine: Tell us what you want, our engineers will do their best
3.We cordially welcome customers to visit our factory, you will be served with professional reception staff, convenience for your
catering and ticket booking.
On-Purchase Service
1free training course. The buyer’s operator will be trained for more than 4days in the seller’s training and repairing center till he/she master basic knowledge on machine usage
2.send technician to install and adjust machine (expense for visa, air ticket, accomodation and catering will be undertaken by buyer)
After-Sale Service
1.Warranty period for one year,maintenance service, support of various software and software upgrading service for lifelong
2. Response time for customer service: arrive in places 500km away within 12hour; arrive in places 1000km away within 24hour; arrive in places over 1000km away within 36hour
To give more according answer upon your inquiry, kindly requested to provide the following questions:
1, Which material do you need to cut?
2, What is working size and thickness?
3, What is your business industry?
