585,743 active members*
5,174 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Putting a rad off an angle
Results 1 to 7 of 7
    Apr 2007
    47
    Hey
    I have a print deviation that has come in from a customer. We do not do a lot of rads that are partially formed at the end of an angle and if we do we usually have length specs for the angle and rad making the blend nice. In this case i need to find this information myself. I can draw it up and make it look nice on software but would like the actual knowledge and points to make it done correctly. This is on a CNC lathe using Fanuc control. Would like not to use cutter comp.
    Specs
    30 degree angle with a 0.6 rad blending it into a flat. Total length of the angle plus rad is 0.8mm MAX smooth transition. total allowed height is 0.15mm +-0.05.
    Sep 2008
    117
    Re: Putting a rad off an angle
    A number of scenarios would fit your description. You'll need to be more specific. A rough sketch might do.
    Gene
    Apr 2007
    47
    Attachment 248254
    Quick sketch from paint since thats about all i have on this computer to use. The .6 rad blends the angle back to the straight.
    Sep 2008
    117
    Is this what you have in mind?
    Apr 2007
    47
    That would be it. The .42 is a .8max dimension but I am guessing you already figured it out and .42 is the length that makes it blend?
    Sep 2008
    117
    Quote Originally Posted by sandrewb View Post
    Not quite. The .42 is where the .15 dimension intersects the 30 Degree angle
    Gene
    Sep 2008
    117
    Maybe these are the numbers you're looking for?
  1. Putting value in a variable
    By Tancuda in forum Fanuc
    Last Post: 06-21-2014, 11:37 AM
  2. v-25 not out putting rotary
    By 1234567 in forum BobCad-Cam
    Last Post: 10-19-2012, 07:19 PM
  3. Putting it all together
    By Zeljkoc in forum Gecko Drives
    Last Post: 11-19-2010, 11:37 PM
  4. Putting my X3 together, will need a lot of help
    By Ed from NY in forum Syil Products
    Last Post: 11-05-2009, 10:00 AM
  5. Putting It all together
    By whitney in forum CNC Machine Related Electronics
    Last Post: 09-30-2006, 12:24 AM
