Hey
I have a print deviation that has come in from a customer. We do not do a lot of rads that are partially formed at the end of an angle and if we do we usually have length specs for the angle and rad making the blend nice. In this case i need to find this information myself. I can draw it up and make it look nice on software but would like the actual knowledge and points to make it done correctly. This is on a CNC lathe using Fanuc control. Would like not to use cutter comp.
Specs
30 degree angle with a 0.6 rad blending it into a flat. Total length of the angle plus rad is 0.8mm MAX smooth transition. total allowed height is 0.15mm +-0.05.
