585,744 active members*
4,021 visitors online*
    Apr 2013
    Fagor File Name Help
    We are using a Fagor 8055 controller.
    Does anyone know if there is a way to add more to a file name than just 6 numerical characters?
    Such as program number 123456.pim having something like 123456(TEST PART).pim
    Is there a "remark" character like ; or ( that can be used in the file name.
    Eric
    Jul 2014
    20
    Re: Fagor File Name Help
    erockejm
    the file name is always 6 numbers .pim. there is no work around.
    but, you can add a comment to the program. in that field you can add any character you want.
    this info will be saved inside the file at first line after the % character
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. 3D CAD file to 2D CAD file for laser cutting
    By Bertho in forum Uncategorised CAM Discussion
    Last Post: 08-07-2013, 11:45 AM
  3. Call file as variable from within a file
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 12-29-2012, 08:23 PM
  4. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  5. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
