585,973 active members*
3,968 visitors online*
    Feb 2008
    231
    G540 fault light
    Hi, I have a G540 that is about 4 years old and has always worked flawlessly. I am controlling it via a CANC CNC interface and operate as a plasma and a router. Last week, during a job the machine stopped moving...however, Mach continued to advance the DRO's as if it was still running. Knowing that the system is open loop I looked into the control cabinet and seen that the fault light was lit on the G540. Because I am using the CAND system I do not use the charge pump option so I have it selected to the off position on the drive. I then moved the charge pump selector switch to the on position and then back to the off position and the fault cleared. I restarted the job and it finished as normal. Today, it did it again? Any thoughts would be highly appreciated.
    Scott Sutton
    Mar 2007
    2083
    Re: G540 fault light
    Hi Scott
    with the charge pump circuit switched off and enable terminal 10 connected to ground terninal 12 via your E stop switch
    the fault detector circuit could be triggered by an overload caused by a damaged G250 driver or motor cable -
    (check the stepper motor cables for damage , try it with all motors disconnected)
    or over voltage being detected
    if you are using a 48V switch mode power supply some times they fail to regulate and the output goes over 48V
    have you contacted Gecko drive ?
    most G540's have 4 identical G250 stepper drivers
    if tests prove one of the G250's is faulty
    it can be removed and the G540 will work as a 3 axic control until the 4th driver is repaired or replaced
    (1 version of the G540 had the step and direction connections crossed and needed a reprogrammed G250 on 1 axis )
    John
    Feb 2008
    231
    Thanks John,
    I will check your suggestions, good information. I have not yet heard back from Gecko.
    Scott
  1. g540 blinking fault light.
    By mredburn in forum Gecko Drives
    Last Post: 04-25-2013, 07:13 AM
  2. G540 Red light = Fault.
    By Squid in forum Gecko Drives
    Last Post: 04-03-2013, 09:21 PM
  3. G540 fault light...what does that mean?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 03-07-2011, 02:37 AM
  4. Fault Light Stays On G540
    By Bob La Londe in forum Gecko Drives
    Last Post: 08-14-2010, 09:04 PM
  5. G540 Fault light
    By cnccustom in forum Gecko Drives
    Last Post: 01-06-2009, 07:53 AM
