586,024 active members*
4,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > Running the tool changer on an Emco Turn 50
    Sep 2014
    I just got a used Emco Turn50 lathe. I am replacing the stepper controller with a Gecko 540 and plan to run it with Mach 3. My dilemma is how to control the 3 position toolchanger. The toolchanger requires approximately a 1 second signal to move 1 position. Can a macro be written in Mach 3 to use one of the Gecko outputs to move it on a tool change command? Any suggestions would be appreciated!
    Jul 2004
    235
    Re: Running the tool changer on an Emco Turn 50
    You may be able to mount a micro switch (or sensor) somewhere on the machine, and just go over with a slide or carriage, and bump it... to signal your tool changer...
    Once you knew the routine, you could possibly convert that to a macro.
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    15362
    rstrohl56
    The tool changer on these Emco machines, will only turn anti-clock wise, they turn a little past the tool position, then move a small amount clock wise to lock in position, the turret already has all the switch's inside for each station
    Mactec54
    Nov 2009
    4415
    If it is anything like my Dyna is. It just rotates as Mac says except that when backing up it stalls the stepper (no harm done) and the tool location is achieved.
    Though switches can be used for verification, homing etc. It is not needed as long as the tool in the holder is verified at startup.
    My Dyna has a 6 tool changer. This is the macro.
    A lazy man does it twice.
  1. What is the best bang for the buck for a turn-key cnc with tool changer
    By johnnyquest in forum Want To Buy...Need help!
    Last Post: 04-24-2014, 03:16 AM
  2. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  3. Denford/Emco Type Tool Changer Questions
    By datac in forum Benchtop Machines
    Last Post: 04-13-2013, 03:28 AM
  4. EMCO PC Turn 50
    By bluepgt in forum EMCO Lathe
    Last Post: 02-02-2012, 10:27 PM
