585,938 active members*
3,188 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Kitamura 3xi w/ Fanuc 16i Alarm problem
    Aug 2006
    8
    My Kitamura will throw up a spindle oil alarm if it sets for a couple of minutes between cycles. Currently we leave it in manual w/ the spindle turning to prevent the alarm from recurring. Is there a parameter to increase the time before this alarm will occur? :idea:
    Dec 2005
    59
    Wouldn't it be better to fix the problem instead of working around it?
    Fixing this is ALOT easier and le$$ costly than replacing the spindle bearings...
    Check the pump/fittings/lines for cracks/leaks. The alarm is trying to save you from costly repairs.
    Jack of all, master of none
    Galveston, TX
    Aug 2006
    8
    there is no problem it a defective sensor or something . we already look at the supply to the spindle and it was perfect.
