584,812 active members*
5,534 visitors online*
    Mar 2013
    Ghosts on 3D relief carving?
    On 3d relief carving I have ghosts ONLY on the left side of carvings, on the place when Z axis come to horizontal plane. It can be seen on pictures.
    Model is from ArtCam and in ArtCam in his simulation everything looks great, but on carvings this ghosts shows.
    I'm tested all 3 axis for mising steps and there are none. Everything is OK.
    Ghosts are on the only left side and only when z axis come to horizontal plane. They are 1-2mm wide and fraction of mm high.
    It's not only on this model, I tried couple of others and it's showing on all of them, somewhere more somewhere less.
    Can somebody help me?
    Thank you.
    Attachment 248796Attachment 248798Attachment 248800
    Nov 2008
    412
    Re: Ghosts on 3D relief carving?
    Its hard to help you without the original file you are working with. Post it here and somebody who is familar with artcam and 3d solids be able to help you. Good Luck.
    Forget about global warming...Visualize using your turn signal!
    Mar 2013
    I can't post it because it's very big file (over 100MB). It doesn't matter what model is in question, on all models it shows the same ghosts.
  1. How to clean up a bas relief carving - advise please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 03-23-2014, 01:32 AM
  2. relief carving software
    By theGoatHerd in forum Vectric
    Last Post: 09-06-2012, 09:55 PM
  3. relief Carving wood
    By Big-tex in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-24-2011, 12:24 AM
  4. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
  5. Relief carving
    By zonker in forum Uncategorised CAM Discussion
    Last Post: 07-09-2006, 11:00 PM
