585,973 active members*
4,041 visitors online*
    May 2008
    84
    ball screw noise (axis jumping)
    Y axis screw is jumping. Maybe about 0.002-0.003". Worse in one direction, and "appears" to be more prevalent in one location. But may be along the length of the travel. It jumps about every 1/2". Perhaps each screw revolution?
    Is this likely:
    1. a bad spot on the screw, or
    2, a bad ball in the nut circuit, or the nut itself, or
    3. a bad spot in the thrust bearing?
    clay
    Dec 2012
    569
    Re: ball screw noise (axis jumping)
    Quote Originally Posted by claya View Post
    Is this likely:
    clay
    I dont know but heres my logic:
    probably not a bad spot on the screw since it happens every 1/2"
    if you know your ball screw pitch you can figure out if its possible that its a bad spot on the thrust bearing or not by using the "happens every 1/2 inch" and the pitch of the screw, and seeing if that lines up or not..i.e. if your ballscrew turns 3 times for every 1/2" and you only see the problem once in that 3 times, then its probably not a bad spot on the thrust bearing
    how did you notice this was happening?
    I also think the screw is very unlikely to cause the problem - any damage there should be easily visible and only affekt a small area.
    Loosen the nut from the rest of the machine so you can rotate it freely by hand without rotating the screw. If it still jumps it is the nut - if not it is the bearing.
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
    May 2008
    84
    There is a distinctive "circle" where the end mill dwells, and then jumps. You can not only see the effect in the cut, but feel the lag & jump during most of the y-axis travel range. I just happens to be worse in a 1-2" area of the travel. Right where the vise range is.
    The screw pitch is 0.4. And it looks like the dwell jumps are also 0.4 apart. Methinks it is the screw now.
    Quote Originally Posted by acannell View Post
    Jun 2013
    1041
    I would bet it's the screw alignment to the axis or a bent screw. It could also be the bearings at one end or the other or the attachment between the motor and screw.
    Ben
  1. X Ball screw noise
    By LEARN in forum Charter Oak Automation Support Forum
    Last Post: 12-19-2014, 12:02 PM
  2. LB4000 EX Z axis ball screw noise
    By iMillJoe in forum Okuma
    Last Post: 11-17-2013, 10:19 PM
  3. DRIVER BALL SCREW NOISE & SHAKING
    By Cruiser in forum Charter Oak Automation Support Forum
    Last Post: 04-19-2012, 09:00 PM
  4. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  5. X axis ball screw nut.
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2010, 02:03 AM
