585,927 active members*
3,590 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10M Overload Alarm PROBLEM 1983 Kira Mill
    Sep 2010
    6
    I'm not sure the best place to put this but here goes:..
    I ran into a SV023 Z alarm on this machine. I figured out that I needed to hit the reset switch on the relay for the Z on the velocity control unit. Now the SV023 alarm is gone but the red LED for "Overload" is still lit. There are no alarm messages to read or anything.
    The "Single Block" button is also lit up.
    I can Auto ZRN no problem, but it still won't let me clear the "overload" alarm LED. I can even jog in handle mode.
    Here is a pic of a similar control unit... my e stop is on the right though, other than that, it's the same.
    I've checked as many fuses as I could find but all appear to be in operational.
    I'm about to bang my head against the wall... can anybody shed some light on this situation?
    Regards,
    Chris
Name:	used-kiramiyano-model-kv3-mc-vertical-machining-centre-w-fanuc-10m-control-p20608205_3.jpg
    Aug 2014
    8
    reset switch on the relay for the Z, is that a motor starter with an overload block? If so the contacts in the OL are likely stuck. That would give the control the signal that the thing is still tripped.
    Aug 2007
    793
    Re: Fanuc 10M Overload Alarm PROBLEM 1983 Kira Mill
    ladder can reveal you the input point (X address)
    then just trace wire from input point of PMC to machine side
  1. Fanuc 3M servo alarm overload signal
    By max_c in forum Fanuc
    Last Post: 09-04-2015, 03:23 AM
  2. Mazak QT20 T1 - Alarm 55 - Fanuc spindle drive overload
    By leito1489 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2014, 01:24 PM
  3. Replies: 0
    Last Post: 11-25-2011, 12:32 AM
  4. Fanuc / matchmaker chip overload/ atc problem
    By cdfracing in forum Fanuc
    Last Post: 04-14-2011, 08:31 PM
  5. KIRA FANUC 10M
    By NEOKO in forum Fanuc
    Last Post: 04-09-2010, 05:19 PM
