585,992 active members*
5,297 visitors online*
Results 1 to 7 of 7
    Aug 2012
    54
    CITIZEN A20 - Fanuc 31i
    Hi All.
    I'm looking for something like this only for Citizen A20 VII
    Who have any example?
    O222(CHECK-START-POSITION)
    IF[#810NE#816]GOTO30
    IF[ABS[#5043]GT[#814/2]]GOTO30
    IF[#5043NE0]GOTO1
    IF[#5041NE#824]GOTO1
    GOTO7
    N1
    M6 (CLOSE MAIN COLLET)
    (CUTOFF)
    T0100
    S1=#817M3
    G0X#814+.1T1
    /M52
    G99G1X#824F#822
    G4U.5
    M5
    N7
    (START POSITION)
    IF[#5022EQ[#872-#818]]GOTO991
    M7
    G4U.2
    G0X#824W0T0
    G53Z#872-#818
    M6
    N991
    M99
    N30
    #3000=70(--CALL-CUTOFF)
    Thx
    Miki2432
    Sep 2011
    261
    Re: CITIZEN A20 - Fanuc 31i
    Have you tried that program in the A20? I think it will work.
    Generally, #5041, #5042, and #5043 (current X,Z,Y locations) are universal across machines. I am not specifically familiar with the A20, but even between mitsubishi and fanuc, the #5041,2,3 variables are the same. My guess is that you could use that exact program. It looks right to me at least.
    So throw it in an A20 and see if it works. My guess is that it works as is.
    Let us know if it works. If it fails, tell me where it hangs up or alarms and I ill help you troubleshoot it.
    CNC Product Manager / Training Consultant
    Aug 2012
    54
    Thank you for your reply. I know what you mean # 5041, # 5042, # 5043. I'm just looking for the A20 macro parameters.
    IF [# present tool NE # cutoff tool] GOTO30
    IF [ABS [# 5043] GT [# bar o.d / 2]] GOTO30
    IF [# 5043NE0] GOTO1
    IF [# 5041NE # cutoff end point] GOTO1
    GOTO7
    N1
    (CUTOFF)
    T0100
    S1 = # cutoff rpm M3
    G0X # 814 + .1T1
    / M52
    G99G1X # cutoff end point F # cutoff feed
    G4U.5
    M5
    N7
    (START POSITION)
    IF [# 5022EQ [# max m / c stroke - # machining length]] GOTO991
    M7
    G4U.2
    G0X # cutoff end point W0T0
    G53Z # max m / c stroke - # machining length
    M6
    N991
    M99
    N30
    Sep 2011
    261
    Ah, I see.
    I believe you can see those variables in the PRM screen under the MC VAR menu. I think (at least on our machines) you should have 10-30 pages of machine variables you can read/view. We dont have Fanuc Citizen machines, so I cant check.
    Feb 2011
    353
    the program that you have listed above will not work unless you change the #800's to the proper numbers.
    the a20-7 has #016 for the material size in the data prep page.
    the other thing would be that you have to change a parameter to be able to read these where as the Mitsubishi the can be read
    if changing the parameter so that you can read them be careful about not writing to them as they be come read and write.
    when you write the program I would be interested in seeing it
    good luck
    rcs60
    Need ESPRIT postrocessor for Citizen A20 VII
    Please send me to [email protected] Best Regards
    I think A20 macro parameters have #12500 to #12513
  1. citizen f25, fanuc 3t
    By jamessiffel in forum CNC Swiss Screw Machines
    Last Post: 09-29-2015, 03:59 AM
  2. Citizen F12 Fanuc 3T Relay problems
    By amercc in forum Fanuc
    Last Post: 10-08-2013, 04:54 PM
  3. Variable Parameters 31 and 32 Citizen/Fanuc Controls
    By amercc in forum CNC Swiss Screw Machines
    Last Post: 07-17-2013, 01:34 PM
  4. Citizen F12 with Fanuc 10T getting SV013 alarm
    Last Post: 06-17-2013, 09:45 PM
  5. Fanuc M140 Citizen Machine
    By Kai_DK in forum CNC Swiss Screw Machines
    Last Post: 08-12-2008, 12:56 PM
