I am working on getting out new videos on the V27 to help everyone understand the value of all the new features.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
As a BobCAD users I am sure you have come to appreciate the CAM tree and how it makes quick work of storing and changing your part programming. Now that we have a CAD History Tree in V27 we offer the same flexibility for your designs. You can create solids and make changes quickly and easily. Watch this video to learn more about our new CAD features!
Al DePoalo
When working with wire frame drawings you may need to trim shapes into or out of each other. Because of this we have added 2D Booleans that use the same work flow as 3D Solid Booleans. The only different in the work flow is you have to rt click ok ( or space bar) after you select the first group of shapes. Again other useful tool for making quick work of creating wire frame profiles.
Al DePoalo
CAD has some very nice stuff
In this video I walk through a sample 3D part. I use a sweep surface based on wire frame, and planar surface based on surface edges. Working with surface edges for design in a new feature in the V27. Once we model the part I lay down a roughing and Z level finish tool path. In the V27 Mill Pro we've added a Zig Zag option allowing the tool to cut back and forth following a profile, almost like a flow line. Once simulated, we go back to the model make some changes and update the tool path. Take a look!
Al DePoalo
Thanks Al ! But be it known that there are some BCCD videos that do not have 'verbal promps'only 'explanation text baloons' these days text baloon videos are harder to understand, having to read the baloon and find what the cursor is doing at the same time.I thinl I speak for many:we love your voice and the twang of After Darl!
Yes thank s AL!
Big Chipin, spreading tha cheese, I be Big Chipin for days!
Using edges without extraction..... Sweet!
Love that Adaptive on the Z level and the Start from Bottom/Up option. That might make deburring my knife blade infinitely easier.
In the BobCAD CAM V27 we've added many new tools for our Mill Professional users. Most of which are aimed to reduce geometry creation to limit tool path. Angle ranges, linking updates, leadin -out updates operational stock are just some of the new features. What this video to learn more.
Al DePoalo
Great videos! I just purchased the standard edition v27. Will you be demonstrating how to achieve some of the features in pro in standard?
V27 lathe?
V27 milling standard
