Is there a way to create this type of 3 axis toolpath in Mastercam X? In Catia, it is called IsoParametric because it follows the UV parameters of the surface. The closest thing I can find in Mastercam is "flowline", which seems to work on some surfaces, but not consistently, and not on this surface (which happens to be planar, but at a slight angle to the Z axis).
The feature that I am looking for is an option to get the path to be parallel to the edges of the surfaces with a nice smooth transition between them.
Can someone help this Mastercam newbie?
