585,942 active members*
3,792 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki Zl 15 SM lathe data transfer
Results 1 to 9 of 9
    Apr 2014
    Hello,
    I recently bought an old Mori Seiki ZL-15 SM lathe from 1990 (2 spindled, C axis on main spindle), FANUC MF-D4 (I believe it's 0T series), I managed to start it (without the C axis since I cannot find suitable live toolholders) and now it's producing. The problem I have it's that I cannot send/receive data using the RS232 connection and the lathe will not accept parametric programming (#1=50 #2=12 etc), for this reason I'm loosing a lot of time writing programs by hand.
    Anyone can please help?
    Jan 2004
    92
    Re: Mori Seiki Zl 15 SM lathe data transfer
    Just wondering if you resolved your data transfer issue ??
    Gunner
    Apr 2014
    Not yet
    Oct 2013
    40
    Post Re: Mori Seiki Zl 15 SM lathe data transfer
    do you check your RS232 setting in parameters?i think this may be fault of your setting.tell me that do you have checked it?
    Feb 2009
    6028
    Probably a 0TT nightmare control. You will need Fanuc option custom macro for the variables.
    Aug 2011
    2517
    basic rs232 info for 0T is here.....
    Machinery RS232 communications settings for CNC controls including fanuc and mitsubishi
    check your parameters and cable. it really isn't that difficult to make it work as long as your machine and communication hardware is working.
    Apr 2014
    All, thank you, managed to solve the data transfer issue!
    Still -I know it is off topic- I could not solve the parametric programming issue, so any input is more than apreciated
    Aug 2011
    2517
    you need macro B. Its an option.
    Mar 2019
    If you still have ms zl 15 sm,please contakt me.
  1. Mori Seiki Fapt file area (materials data garbage)
    By bateson1993 in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2013, 03:33 PM
  2. Mori Seiki 2500 Y MSX 850 III transfer data
    By beyegladcnc in forum Mori Seiki lathes
    Last Post: 08-19-2012, 01:46 AM
  3. Mori Seiki MSC803 GOP data
    By ejaz199 in forum Mori Seiki lathes
    Last Post: 05-18-2011, 12:36 AM
  4. Mori Seiki SL-403 Lathe
    By alc1960 in forum Mori Seiki lathes
    Last Post: 09-23-2008, 03:35 PM
