585,702 active members*
4,185 visitors online*
    Apr 2013
    11
    lag error on x-axis
    I was wondering if anyone has ever encountered a lag error before. I'm relatively new to waterjets and the college I teach at has a Flow waterjet controlled by a power automation (pa 8000) control tower. Everything worked fine on it one day and then the next day when we booted it up, we got a "CNC error 481-Lag error on stand still on x-axis". When ever we try to hit the reset button on the tower, the heads jumps around sporadically on the x axis. Called power automation and they tried to blame Panasonic and their drivers and Panasonic tried to blame Power automations PLC's. We can't seem to get any help from any of the companies. We had to gut the tower a little over a year ago and put in the power automation controller because the original controller dies on us.
    Any thoughts on this? We took the covers off the x-axis and made sure the screw and the ways were clean and lubed and tried running the machine without the belt on the motor to see what kind of a signal the motor was getting. The motor was causing the x to jump around when reset was hit. To me that says its something in the cabinet.
    Thanks!
    Apr 2013
    11
    Re: lag error on x-axis
    Found out that I had to reset parameters on my motor drivers. After I did that and reloaded the CNC parameters, it was running like new.
    Nov 2021
    Hello, I have a similar issue. How did do that? thank you
    How to reload the CNC parameters? How to check CNC parameter? Please kindly advise.
    I used Panasonic servo driver and power automation (pa 8000) same as you. Found the same issue. so How about now? your motor is working? or you have other solution. Please kindly advise
  1. error 368 X AXIS : SERIAL DATA ERROR (INT)
    By mattpatt in forum Fadal
    Last Post: 02-24-2023, 02:01 PM
  2. U Axis excess error + Y axis over travel?!!!
    By jaine in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2013, 06:45 AM
  3. Z AXIS ERROR
    By efmautoclutch in forum Milltronics
    Last Post: 04-03-2011, 05:12 PM
  4. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  5. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
