Hello all,
I am hoping one of you has experienced this problem and can help me find a solution.
I am running a CNC Plasma table using Mach3. I am creating my g-code using Sheetcam. Everything has been working fine including the run from here function in Mach3. That is until I installed a Proma THC and a floating z axis last weekend. The THC and the floating z work as expected (although I will likely up-grade to a better THC).
However since the installation, I have discovered that I am no longer able to stop the machine and then restart using the "run from here function". Whenever I try, the Mach3 software resets to the line immediately following the first line of g-code containing a g31 code instead of the line requested. It also does not give me the usual reposition request. So, I am forced to reload the code and run from line 1.
Any help would be greatly appreciated.
