585,749 active members*
3,660 visitors online*
    Sep 2014
    Question Write system variables by Focas2
    Hello, I need help.
    I'm building a kind of monitoring system for NC Machine(5 axis milleing, Fanuc 31iB).
    In this system it monitors loadrate and when the loadrate is bigger than I expect the machine should be stop.
    So I'm trying to make alarm or the machine stop by Focas2. (I'm using ethernet communication with Focas2 for this system.)
    I would like to use system variables #3000 or #3006 to make alarms or masseges.
    But I couldn't.
    I used for this the Focas function, cnc_wrmacro, and the description says that it can be used for system variables(#1000~#9999).
    Other system variables, #3001, #3002 and etc, works well. I can write some value with cnc_wrmacro function.
    But when I try to write some value to #3000 ro #3006 EW-NUMBER(3) error is returned. That means the number of variable is wrong.
    If there is anyone who are good at using Focas, please give me a idea.
    Thank you in advance.
    Sep 2014
    Re: Write system variables by Focas2
    Is there anyone who can handle this?
  1. System variables
    By ChattaMan in forum Okuma
    Last Post: 09-05-2019, 05:19 PM
  2. System variables
    By dinglekiller in forum Parametric Programing
    Last Post: 10-15-2012, 09:14 AM
  3. System Variables???
    By springer82 in forum NCPlot G-Code editor / backplotter
    Last Post: 03-12-2011, 07:39 PM
  4. System variables
    By jorgehrr in forum G-Code Programing
    Last Post: 02-19-2007, 02:26 AM
  5. Possible to write variables to a program?
    By Heavy D in forum G-Code Programing
    Last Post: 08-22-2006, 05:08 AM
