Re: Newby and a bit overwhelmed
Parkker,
The company that built your machine should be able to provide a XML file (unique to your machine) that has the parameters Mach3 requires.
Simply copy the xml file into the Mach3 folder and you are good to go.
Welcome to the Zone,
Jeff...
Originally Posted by
Parkker
Hello all,
Just yesterday got a X61500GTUSB from carving-cnc. I was hoping this would be a bit more plug and play than it is! If the company supplied instructions it would be great. They have a nice users manual with color pictures that tells how to assemble it but what is needed is a comprehensive guide to all the proper settings to be made within the Mach3 program in order to make this operate smoothly. I have been experimenting with it and finally found the Quick-Start guide posted here. That helped a lot but still not quite right...
Parkker
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
