Hey guys,
I'm having a bit of an issue defining a chamfermill correctly.
The tool I've got is a 9Nine chamfermill, it's a single insert 90 deg chamfermill. The insert has a .8mm nose radius.
My question is how do I define a chamfermill with a nose radius and one flute?
I've selected chamfermill and set the following,
Outside Dia: 0.586"
Taper Angle: 45
Corner Radius: 0.031496 (0.8mm)
Diameter: ???
It makes sense that the "Diameter" should be zero because this tool doesn't have a flat on the tip, but no matter what I try the preview of the tool looks like some kind of wonky dove-tail cutter.
Any ideas?
