The drive is a AMC be25a20ac
The servo is a ABB type 641.2.30 92/34 (cant find any actual documentation on this one)
In the process of trying to do a basic tune in test mode.
following the main install guide with references to the drive manual
This is a bench test, nothing is attached to the mill or the computer as per the manual.
After much trial and error and consulting the documentation repeatedly it dawned on me that it is a 60 degree motor instead of 120 degrees. Fiddling with the hall sensors I stumbled across 2 positions that would not result in a fault but only one would actually allow the motor to spin. Unfortunately in one direction only. It spins clockwise just fine. CCW however I have to manually turn the motor and it does so grudgingly and will not turn without constant force.
Oddly I got it to turn better using 120 degree phasing, but it produces a fault condition due to the invalid hall state, if it spins slow enough it will stay in the fault state and you have to nudge it.
The hall sensors test fine, I don't have an Oscilloscope to verify motor and hall phase relationship. It's just been trial and error with the pin out and watching that blasted fault light on the drive.
