585,766 active members*
4,075 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Is there alternative to Corian
Results 1 to 7 of 7
    Sep 2014
    10
    I have been using random scraps of 6mm Corian for Lithophanes because I can't find an alternative supplier.
    Is there another material i can use for Lithophane ?
    Any small quantity supplier in UK ?
    Jun 2013
    1041
    Re: Is there alternative to Corian
    Use cast acrylic. It comes in opaque and transparent colors. Avoid extruded like the plague for this use. It works great. Here's one I did in transparent blue acrylic.
    Jun 2013
    1041
    Sep 2014
    10
    Thank you very much for your reply, I will get some.
    Nice lithophane ! What acrylic thickness did you use ?
    I still make mistakes with selecting the correct tools for roughing and finishing :=(
    Roy
    Sent from my GT-P7310 using Tapatalk
    Jun 2013
    1041
    I use 1/8" or 3mm acrylic. If done right you could probably use 1/16". As for tools I prefer ballnose cutters in 1/16" and 1/32". I have been successful with engraving bits as well. In 1/8" material the total cut depth is less then .06 inches. I also rarely run a finish roughing pass for these types of things. The horse was done in one pass. Try to get paper masked acrylic. You can leave the masking on till after its cut so it doesn't get scratched up.
    Ben
    You might want to contact any local solid surface countertop fabricators in your area, and ask if you can buy their sink cutouts and or scraps.
    Sep 2014
    10
    Thanks Ben that's very useful. I sourced some cast acrylic on eBay over the weekend to try. I will look for a local supplier as well.
    I am impressed with your one pass result, that must save a lot of time .....another great tip for me to try. Hopefully ....watch this space for my effort !
    Roy
  1. Bonding Corian to Corian. What to use?
    By mcphill in forum Composites, Exotic Metals etc
    Last Post: 08-16-2016, 08:54 AM
  2. corian maching
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 11-07-2011, 11:16 PM
  3. corian for lithopane?
    By Claude Boudreau in forum Glass, Plastic and Stone
    Last Post: 03-29-2009, 04:43 AM
  4. Vac forming Corian?
    By fer_mayrl in forum Vacuum forming, Thermoforming etc
    Last Post: 08-22-2007, 12:15 AM
