585,758 active members*
4,568 visitors online*
Results 1 to 6 of 6
    Aug 2005
    52
    Proper feet for my machine
    When I bought my cnc machine, the guy gave me 5 of the round feet in the attached picture. But there are 6 adjusters on the machine. Also, I think he said there should be ball bearings between the feet and the adjusters on th e machine. At the time, I just put the machine down on it's adjusters but it was really too low to have the coolant tank in the proper position. Can someone fill me in on what I'm actually supposed to have and where I might get it?
    Thanks.
    Edit: By "Ball Bearings" I really meant "Ball Brearing", as in a single large steel ball.
    Feb 2009
    6028
    Re: Proper feet for my machine
    No bearing. Leveling screws just sit on those. Helps to put grease between them. The hole through is to anchor the machine down. Seen this same style on Moris and Okumas.
    Aug 2005
    52
    Thanks, any idea where I might get a 6th foot?
    Feb 2009
    6028
    Got a lathe?
    Aug 2005
    52
    Only a little harbor freight 7x10. It would take me forever to make one, I'd rather just buy one.
    Aug 2005
    52
    I suppose any hunk of metal that is in the vicinity of the same height as the others would do...
  1. Machine feet - Buy or make your own?
    By murak in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-03-2013, 07:50 AM
  2. Getting my feet wet
    By M250cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 07-07-2010, 09:18 AM
  3. proper name sheet metal stamping machine?
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2010, 05:30 AM
  4. Need help in buying proper cnc machine
    By drgilson in forum Commercial CNC Wood Routers
    Last Post: 04-07-2007, 11:51 PM
  5. Proper ways to fuse your machine electronics
    By freak_brain in forum CNC Machine Related Electronics
    Last Post: 07-17-2005, 02:55 AM
