585,885 active members*
6,328 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Harbor Freight 7x10 conversion help
Results 1 to 6 of 6
    Jul 2009
    115
    Hello,
    A few years ago I purchased a Harbor Freight 7x10 lathe with the intention of converting it to CNC operation. Things got busy and I never got around to it. I am now an empty nester and have time to work on some projects, but when I went to CNC Fusion it appears that they no longer sell a kit for doing the conversion. Unfortunately, all of the searches I have performed since then eventually lead to dead links. Does anyone know where a conversion kit for the lathe can be found? I don't need motors or electronics, but I do need mounting plates since I currently have no way of making those myself.
    Thank You!
    Sep 2005
    17
    Re: Harbor Freight 7x10 conversion help
    can you draw the part and e mail the file to a shop to be made ? just an option
    Nov 2009
    4415
    Where are you? Another member might be your neighbor.
    A lazy man does it twice.
    Jul 2009
    115
    I am in the Charlotte, NC area.
    Sep 2005
    17
    Chicago area
    Apr 2004
    733
    Here's a conversion I did that might give you some ideas. It was a very simple conversion due to using a thk linear axis and ballscrew purchased from ebay. All the aluminum mounting plates were just cut from flat bar and with drilled/tapped holes. I used a bandsaw and drill press but there is no reason why it couldn't be done with a hacksaw and hand drill. Good luck.
    CNC Lathe
  1. Harbor Freight Precision Mini Lathe 7x10 Won't Run
    By yoyospirit in forum Maintenance DIY Discussion
    Last Post: 05-23-2014, 12:19 AM
  2. Harbor Freight 7x10 tool post question
    By signal15 in forum Mini Lathe
    Last Post: 05-06-2011, 03:10 AM
  3. Harbor Freight 7x10 Lathe (#93212) Questions
    By Dman65 in forum Mini Lathe
    Last Post: 07-27-2009, 04:15 AM
  4. harbor freight 7x10,fuse blown,not working
    By fpm in forum Mini Lathe
    Last Post: 06-21-2009, 12:06 AM
