Hi all,
I am going to attempt to design and build a 5 axis CNC. I have the machine rough designed and am now working on modeling the fine details. I am working on trying to figure out the A/B axis stepper motor. I currently have the stepper motor transferring power thru a timing belt to my spindle holder. I chose the timing belt as apposed to direct drive so that I could potentially get a finer resolution.
I found this website that goes thru and helps you calculate what motor you need, but it performs the calculations based on screws transferring the power.
What size stepper motor do I-need.
I tried to follow the site, but I wan't sure what equations would pertain to my situation.
So here's what I got.
Weight of the spindle and the spindle mount : 2.75kg
The CG of the spindle and mount is roughly 27mm below the center of rotation (not sure if this is necessary).
I plan on only cutting wood, so based off the link above, the forces pushing against the spindle from the wood is about 5N. I don't know if this is for soft/medium/hard wood, so I figure a 10N force against the spindle would be more than enough to cover milling a hard wood.
The force based off the spindle and mount = F = m*a = 2.75kg * 9.81m/s^2 = 26.98N
Add the two forces together give 36.98N
The torque exerted on the spindle during a cutting pass would be = T = F * r
The radius from the center of rotation to the end of the spindle is .108m.
T = 36.98N * .108m = 3.99Nm
From the stepper motor to the spindle, I plan on having a gear reduction (is it still a gear reduction even though they are pulleys?) of at least 1:3. Probably more if I can find adequate pulleys. So with that gear reduction of 1:3, we have 3.99Nm / 3 = 1.33Nm.
I would like a factor of safety of 2, but would settle for less if I needed it. With the factor of safety of 2, the output torque (pullout torque I think is the technical term) of the motor will need to be 2.66Nm.
2.66Nm = ~27 kg-cm.
To me, my 2.66Nm doesn't seem right at all compared to the example in the link. The example in the link above has a required torque of .052Nm to move a 20kg item. The link above also uses static coefficients, which I don't. I especially think mine is wrong since I am having a hard time finding a motor that has more than even 20 kg-cm. I could go with more pulleys for a greater gear reduction, but then I might run into spacing problems (haven't really looked at this option yet), and by the time I buy the two extra pulleys, the shaft, two bearings, and belt, I'm guessing that I will have spent as much on the hardware as the difference in price for the motors.
Could someone look over my steps and tell me what I did wrong? Could you show me the equations so that I can apply them to my design? If for some reason I did solve this right, could you tell me where to find a motor that is that strong?
Thanks for everything,
-David
