I have a lathe with a 4-position rotary toolchanger. It is turret type toolchanger, and it can hold multiple styles in each position. I've already got the toolchanger macro working for this with help from the forum. This question is more about how to use this type of toolchanger &Mach3 with drill bits. I'm a hobbyist & repair person, so most of the work I do is one-off items.
This is no problem with standard turning tools because I typically use the same DNMG RH tool no matter what I turn. However with drill bits, they change with each operation, and to add complexity many times are different Z lengths as you change size. I would only typically put one drill bit in the toolchanger in a standard position which has the drill chuck MT adapter.
My initial though to reduce multi tool complexity in the tool table of Mach is as follows: Set the face of the drill chuck as Z=0 as part of standard tool entry setup. Of course X=0 would be set on the centerline. Then, in my gcode I would always call this tool not matter what drill bit planning to use. When setting up for a job, I would put in the drill bit, measuring how far it extends from the face of the chuck. Then, in Mach, I would use the 'Z Wear' setting to input this length measurement for that tool designation. Then Mach would automatically add in the wear dimension to the tool offset, taking care of the drill bit length.
Looking for feedback on how you think this would work?
Nick
