585,763 active members*
4,076 visitors online*
    Apr 2012
    Unhappy CUTTING CIRCLES!
    I have two CnC machines. They are both Selexx Pal's. One is about 25 years old and the other is brand new... For some reason when I try to cut 32" diameter rings I'm getting an egg shape!!! Both machines are doing this and I can't figure out why!!
    I'm cutting 3/16" aluminum sheets (3 passes) with a 3/8" end mill. I've never had issues with circles before. Running EnRoute(version 5) software on a PC. Any thoughts??? Seems more like a software thing to me...
    Any ideas help!!
    thanks!
    -Dylan
    Mar 2006
    2712
    Re: CUTTING CIRCLES!
    Could be mechanical. Slop (backlash) in ballscrew(s)/nuts, excess motion due to loose bearings in the ballscrew support bearings(fixed end), compliance in the ballnut mount.
    Could also be the timing of the axis drives have gotten out of sync.,
    Dick Z
    DZASTR
    Apr 2012
    90
    I'm not familiar with your software but check to see if there is some kind of arc deviation in the software and set it to 0. You may have to take a couple finish passes with the feed rate turned way down.
    Is your program trying to do it line by line or in arc movements? That makes a difference also.
  1. Is anyone else having problem cutting circles?
    By FoxCNC1 in forum Avid CNC
    Last Post: 04-22-2017, 11:07 PM
  2. Help Cutting circles TM2 router
    By John999 in forum Torchmate
    Last Post: 09-19-2008, 10:41 AM
  3. cutting circles.....and G code
    By greenene in forum Uncategorised CAM Discussion
    Last Post: 06-17-2008, 11:09 AM
  4. Cutting arcs and circles
    By inaman in forum GibbsCAM
    Last Post: 04-26-2008, 08:04 PM
  5. Cutting circles and arcs
    By Hack in forum CNC Machine Related Electronics
    Last Post: 11-08-2004, 10:12 PM
