I am building a CNC foam cutter and am looking for a source for buying the timing belts and drive gears. Appreciate any links or direction.
Rich
Rich
http://www.sdp-si.com/
(Beat you to it, Al!)
Scott
Consistency is a good thing....unless you're consistently an idiot.
Do a search through the forums here, lots already mentioned.
Al.
Albert E.
What is the standard size people strive for for a simple design, and gear reduction?
Try McMaster Carr. Expensive but speedy delivery and they ususally have what you are looking for!
Bill
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Point of correction:
Cogged timing belts and/or chains are used with SPROCKETS, not gears.
Gears transmit power directly from one to the other via tooth to tooth contact.
Ask for and/or purchase the wrong thing, and you could become highly disappointed with the parts you get.
