This is my first machine and my first design. Maybe not smart to do it all on the first go but something I wanted to do.
So the plan is a fixed gantry desktop setup. Working envelope is 12" x 18" x 4". I don't have any plans really to do anything over a sheet of wood thick but I probably will in the future so I just picked 4" in the Z out of thin air - any suggestions otherwise? Will primarily be working with wood though I'll likely mill a PCB at some point. I'd also like to be able to do some light aluminum work, as in cut some parts out of 1/4" sheet.
What I've come up with so far is to get a complete drive/linear motion kit off the bay with SBR20 linear bearings and 1610 ball screws. I already have an electronics kit from Keling wth 3x 381oz-in steppers and g540 driver and power supply (48V IIRC). The main frame and gantry up-rights are 1545 profile 80/20 with the frame having 1530 cross pieces to mount the rails on. The gantry cross piece is 3060 and there is a piece of 1/4" x 6" steel plate on the front of that to make mounting the Y axis rails easier. Plates for Z axis and router mounting plate are 3/8" aluminum. FWIW that is a bosch colt drawn on it now (I already have one) though I might opt for a slightly larger unit.
Sorry no fancy renderings and the colours are arbitrarily chosen just for contrast. I haven't drawn in much of the finer details yet like stepper motor mounting plates, limit switches, etc. as I wanted to get some input on how I'm doing so far. I'll also change the router mount to something that helps stiffen the plate that it's mounted on as well. One concern I have is I haven't figured out how I'm going to attach the gantry up-rights to the frame and it looks like a weak point to me. Ideas?
Thanks for any help,
Ryan
