585,942 active members*
3,388 visitors online*
Results 1 to 13 of 13
    Jun 2011
    4
    Is it feasible to cut out letters from candle wax?
    I want to cut out letters from a sheet of 6mm candle wax. Would using a laser make good cuts without damaging the letter like melting it?
    Apr 2004
    5737
    Re: Is it feasible to cut out letters from candle wax?
    Why don't you try it and let us know how it worked?
    Andrew Werby
    Website
    Jun 2013
    1041
    Or you could cut a cavity in something like ldpe or polypro and pour the wax in. Pop them out when they cool and your good to go.
    Ben
    Jun 2011
    4
    I don't have a laser. I am thinking of buying one but I need it to be able to cut out letters from 6mm candle wax that look relatively nice. I don't want to spend so much money and then find out it's not doable. If anyone has done this before or wouldn't mind doing it as an experiment and telling me what were/are the results, I'd greatly appreciate it. I've scoured the internet looking for examples or stories of this kind of laser cutting and have found nothing.
    Jun 2011
    4
    Quote Originally Posted by bhurts View Post
    Ben
    I'll look into this. May be a good alternatve.
    Hi
    if use laser to cut on wax,it will get melt
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
    Feb 2007
    711
    I would look into hotwire cutting, it may work well. I think laser may be a fire hazard.
    Casting does sound like the best way to do it.
    Feb 2013
    38
    I've tried it with sealing wax - and weirdly, it is very very difficult.
    The problem (appears to be) that the laser doesn't burn the surrounding wax - it melts it, and the wax just flows in to fill up the hole.
    It may be that sealing wax is different from candle wax - but I wouldn't have thought it was that different.
    Jun 2011
    4
    thanks, that's helpful.
    Jan 2008
    940
    I tried in candle wax and it just melts and refills
    Aug 2015
    Hi there,
    the post is a bit old,
    but i tried cuting some candle wax, as everybody noticed, it melt with the laser and resolidify just after,.
    I was wondering if anyone had found a solution to cut it.
    I was thinking that maybe if we added in the wax a chemical that would extend the solidification time so we could extract the cut before it solidify again?
    May 2015
    135
    Seems like a terrible idea using a laser on something that melts, lasers generate tremendous heat where they cut...
    Try cutting it with wire to shape it or a sharp knife, even a cnc machine would be better if you must do it with a machine.
    Quote Originally Posted by danass View Post
    Hi there,
    Jun 2014
    611
    No, it will melt.
  1. Power draw bar idea - Feasible?
    By PsyKotyk in forum Benchtop Machines
    Last Post: 07-05-2018, 03:52 PM
  2. Is this feasible as a DIY build?
    By gmcurrie in forum DIY CNC Router Table Machines
    Last Post: 10-08-2010, 12:01 AM
  3. Selling Okuma Macros, How feasible?
    By compuslave in forum Okuma
    Last Post: 04-05-2009, 05:58 PM
  4. How feasible...
    By DeusExMachina in forum Mini Lathe
    Last Post: 03-27-2009, 02:28 PM
  5. Candle cutting
    By interflexo in forum Material Machining Solutions
    Last Post: 01-15-2007, 10:45 AM
