586,005 active members*
5,130 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Problem tension wire machine sodick AQ535L
Results 1 to 3 of 3
    May 2011
    5
    Good day
    The procedure was performed for calibration
    without wire
    VOUT and GND = 60mV
    TENSENS and GND = 300mV
    As indicated in the procedure
    And turn on the machine. H00207 shows alarm. Tension abnormal press ENT to continue
    And after a few seconds. E00180 shows alarm. Excess discharge time (SH) press ACK
    Thanks for your time
    May 2011
    5
    Re: Problem tension wire machine sodick AQ535L
    Quote Originally Posted by mayelo82 View Post
    Good day
    without wire
    VOUT and GND = 60mV
    When I turn on the machine is servo drive MSDA013D1A. marks (ERROR 14 Overcurrent)
    could this be the cause of the failure of the tension wire
    Dec 2019
    Having problem with condition 777 showing short-circuit been told to change the fuse no clue where the fuse is any help will be greatly appreciated
  1. sodick mark ix wire cut EDW nec 9801 uv problem
    By Simon.muthike in forum EDM Discussion General Topics
    Last Post: 10-11-2023, 12:00 PM
  2. Wire-Sodick A535 problem
    By Stiga in forum EDM Discussion General Topics
    Last Post: 09-23-2012, 04:24 PM
  3. Sodick AQ535L
    By soren60 in forum EDM Discussion General Topics
    Last Post: 06-15-2012, 10:04 PM
  4. New Sodick Wire EDM Machine (Affordability)
    By AppliedMachine in forum News Announcements
    Last Post: 01-11-2009, 04:14 PM
