585,762 active members*
4,092 visitors online*
    Oct 2014
    Discovery 308 speed control
    Thanks in advance, can anyone tell me how to change the spindle rpm. I found out how to change feed rate I now need to know how to adjust the spindle rpm.
    Nov 2004
    3028
    Re: Discovery 308 speed control
    DX-32 control? It has a spindle drive. Look for STM. Input a Speed, just press enter to skip T, and a M3. You may have to press start. You need a operating manual.
    Oct 2014
    Yes a dx-32 control. The STM will not alter or adjust the once the program is running. I'm thinking it should be like adjusting the feed rate while the program is running just for the spindle.
    Nov 2004
    3028
    It depends on the version of software. Could be arrow up/down, or +/- keys.
    Sep 2009
    Quote Originally Posted by machintek View Post
    I assume you have a S command in the program and want to over-ride it while running the program? There is a jog +/- button on the control panel, turn to + and push it to increase. - to decrease.
  1. 180V DC Motor Speed control Neco speed controller card - PLEASE HELP
    By gridevolver in forum CNC Machine Related Electronics
    Last Post: 01-22-2019, 06:44 PM
  2. Damp? Sieg X1 speed control and stepper control.
    By Memran in forum CNC Machine Related Electronics
    Last Post: 02-05-2014, 10:16 PM
  3. Cutting speed locked to Z torch height control speed
    By Beefy in forum Mach Plasma / Laser
    Last Post: 02-15-2010, 12:14 AM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  5. Bridgeport Discovery 308 W/SX-15 Control Start up disk needed
    By Richardd in forum Bridgeport / Hardinge Mills
    Last Post: 07-10-2006, 02:07 PM
