Hello everyone not a good day so im hoping i could get some help. I have the 2.2 KW spindle with the corresponding inverter from Huanyang inverter. Had it all hooked up running good but i noticed it kept saying it was only reving up to 11520 at 400hz Max. So i was making some changes in the settings
Normal
PD000 - 0
PD001 - 0
PD002 - 0
PD003 - 400
PD004 - 400
PD005 - 400
PD006 - 2.5
PD007 - .50
PD008 - 220
I adjusted PD004 - to 50 (says that is the factory setting) turned it back on, sounded funny, within 5s smoke came out of the motor. My inverter now says DL error and wont run no more. Was this my fault or was this something on their part? Says its factory setting - can be adjusted to .01-400 hz. What should i do to get this fix or any recommendations?
