585,933 active members*
3,911 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > PM3D Contours drill holes
    Nov 2008
    79
    I am a noob with PM3D. I import a solid IGES model into PM3D. I select the faces and export to DolphinCad. The solid contained drilled holes as well as pockets and large through holes. PM3D or DolphinCad sees the drill holes as contours. So the representation in DolphinCad has only contours. How do I make the contours into points so I can get a drill hole pattern instead of contours?
    John C
    Nov 2008
    79
    Re: PM3D Contours drill holes
    Never mind, I figured it out. PM3D makes ALL circular holes into contours. For those holes that are drilled you have to EXTRACT the circle from the contour in CAD (which deletes that contour but keeps the geometry) and then add a point at the center of the circle. Go to milling module (CAM) and then use that point in the drill pattern. If I had 500 drilled holes this would be a pain.
    John C
    Feb 2007
    412
    Hello,
    PM3D should create Patterns for all circles it finds of the same diameter.
    Could you send me the IGES file so that I can investigate please.
    [email protected]
    ATB
    Andre
    Nov 2008
    79
    Andre,
    Email with iges sent.
    John C
  1. Arg. Can't drill holes in 3d object
    By tome9999 in forum BobCad-Cam
    Last Post: 03-23-2011, 12:20 AM
  2. What is the best way to drill holes?
    By jharvey407 in forum WoodWorking Topics
    Last Post: 12-29-2010, 02:07 AM
  3. Trying to drill many #8 holes.
    By ErnieD in forum MetalWork Discussion
    Last Post: 05-10-2008, 06:17 AM
  4. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
  5. drill dwell between holes
    By EVERFABCHAD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2006, 01:15 PM
