584,858 active members*
4,860 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tutorials > BobCad CAM problem setting origin to center of circle in stock wizard
    Jan 2007
    92
    Hi All,
    I have what should be a simple problem. When using the stock wizard I want to set my machine origin to the center of a circle on the part. This is drawn as a circle in AutoCad, not as a solid. When I click on pick origin and then shift-click on the circle it displays 8 points on the circle, but not the center. What am I doing wrong?
    Dec 2013
    290
    Re: BobCad CAM problem setting origin to center of circle in stock wizard
    Either sketch a point in the center of the circle, so you can use the point as the origin. Or create a new UCS, centered in the circle. With either method, you will want to create them at the z height you want your zero to be set at.
  1. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
  2. Newfangled Circle wizard problem
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 02-23-2012, 06:27 AM
  3. Lead out setting for 2 circle same (center)
    By bbqa01 in forum Mastercam
    Last Post: 08-15-2011, 01:52 AM
  4. Replies: 2
    Last Post: 07-15-2011, 12:36 AM
  5. circle cutting wizard problem
    By kb7vms in forum Mach Wizards, Macros, & Addons
    Last Post: 11-06-2006, 06:14 AM
