Hi, I have just taken receipt of my Leadshine Easy Servo drive system that I intend to use for my CNC Router Build. However, I have rather foolishly only recently realized that I will need a Motion Controller to use these closed loop stepper motors to the full potential. I have done some research and seems that my machine will now get considerably more complicated using a Motion Controller and i hadn't anticipated the cost of these devices.
The KFLOP seems to be the Motion Controller of choice and I had narrowed down to this, however I have just noticed that the KFLOP doesn't accept differential encoder inputs but rather single ended. Unfortunatelly my Leadshine Easy Servos use differential signals for the encoder outputs, which creates a problem. Continuing my reading of the Dynomotion F.A.Q.s I see that i can use a Kanalog device with the KFLOP to provide the differential encoder signals that I require, and now this where my problem starts.
The KFLOP is 249 USD + tax and for it to fit my application it seems I have to add on top of this an additional 249 USD + vat for the Kanalog, which now puts the solution out of my price range at almost 500 USD + vat. So now it is more expensive than the Leadshine DMC2410 motion Control Card, which is also too expensive.
So, my questions, is there a way around this, is it not possible for me to just use the KFLOP and configure the encoder inputs some how......?
any help would be very much appreciated.
sincerely
G.
