585,717 active members*
3,814 visitors online*
    Apr 2012
    35
    software problem engraving problem please help
    Hi
    My name is Goran. I'm not so new in laser cut machines and industries but I have a problem that I have not had before ever.
    So I will start with my machine it is CO2 sealed laser cut machine originali with 80 watt tube but few days ago I've changed it down to 60 watt, because it is more stable with cardboard and paper and it's good also for the other materials that i'm working with.
    So before that machine was working correctly, but now I have a problem with engraving.
    Exactly yesterday I did a few test examples after finishing setting up machine and it was engraving and cutting pretty fine, but today when I tried again to do some gift card it sturted to jump a few times(like once on the left and than on the right but jump like few centimeters ) on engraving and after that the laser had continue going but it won't stop even if I tried pause and stop button on the machine and the only way was thru the emergency stop button. I tried again with new file after re-instaling the laser cut software in to my pc ( i thought maybe that is the problem) , and it was same and same again - jumps twice or three times and after that no command button is working only emergency stop.
    And the cutting is working just fine even with the high speed like 70 or 80
    And I also tried to re-install the driver into the MPC 6515 card from the pc but the pc crushed few times and I can not finished that, so i thought maybe it is a problem version of the windows 7.
    So please please anyone if can help me with the machine I'll be saved i guess.
    Thanks a lot,
    Goran
    p.s If I wasn't clear with english though I wanted to say is that when the engraving proces start, the head is engraving few lines of the picture, text or so from the point that it should and after few lines it jumps( goes ) few centimeters away either left or right continuing with the engraving proces and then again jumps and the head is going slowly withouth engraving or so and the only thing I can do is to press STOP emergency button. And with the cutting proces everything is fine for now.
    thanks again
    Goran
    Re: software problem engraving problem please help
    this problem may cause by static electricity interrupt
    you can make some test by disconnecting the plug of power supply,then run your file,if this problem disappear,then can ensure the problem
    good luck!
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
    Apr 2012
    35
    Hi Tina,
    Thank you for the answer. I will go and check that now and will see. What should I do if that is the issue, should I make some changes on the power supply or ?
    Anyway first i should check
    Thanks again
    Goran
    Apr 2012
    35
    Hi Tina
    I think I solved the problem. Voltage from the power supply was too high for the tube ( because I didn,t buy new for 60watt tube, I'm using the same power for the 80w tube) and I put it down to 24kv like it should be for the tube and now it is working ok, only the test hole that is fired for the test looks a bit bigger than I think it should be. So my father is now making another regulating device (we think better ) so the hole will be smaler and than i'm good i guess.
    If there is something else that i should know please tell me.
    Thank You for you're help.
    Best wishes
    Goran
  1. Engraving Problem's
    By weirdharold in forum UG NX
    Last Post: 10-12-2016, 04:10 PM
  2. engraving problem
    By murphyc1 in forum GibbsCAM
    Last Post: 02-27-2014, 08:17 PM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. Engraving Problem
    By g1r9a6d8y in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-08-2011, 04:43 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
