585,973 active members*
4,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 4 "error 02 fault detected"
    Dec 2007
    126
    Running along, basic mill program. Stopped as usual, loaded another part, and got the error.
    Have powered off and on several times.
    It will home/grid out fine, jog around fine.
    Will not run any programs
    Unfortunately, the manual I got with the machine is jumbled, and after digging through it for 1/2 hour, I cant even find a mention of error codes.
    Any help appreciated, this is holding production right now! Thanks!
    Dec 2007
    126
    Re: Centurion 4 "error 02 fault detected"
    I did find a number of my Program Parameters match Machine Parameters. I have to guess they were accidentally entered at some point in there. But nothing has been touched on parameters in many months.
    Sep 2010
    529
    I have an appendix of error codes, not sure if it's specific to Centurion 5, as that is the control I have, but 002 says "File not found, File name specified as OLD does not exist. Try MENU." I'll see if I can attach the pdf of error codes I have for you....
    Oct 2008
    427
    Here are the Cent4 error codes and a troubleshooting guide.
    This list says an error 2 indicates a low lube alarm, add oil to the lube pump and see if the error goes away.
  1. Milltronics Centurion 5, will not "Reset" properly.
    By Racecast in forum Milltronics
    Last Post: 07-17-2014, 04:37 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 05:35 PM
  4. "Homing Milltronics Partner 4/Centurion 5"
    By RonRogers in forum Milltronics
    Last Post: 06-02-2010, 11:00 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
