586,000 active members*
4,861 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > dq542ma power supply question
Results 1 to 7 of 7
    Jun 2014
    8
    I have 4 dq542ma drivers and 4 57Hd0401-15sb motors and Am not sure on which power supplies to choose. all I know is I need one for the bob and drivers which is 5v and the other one I believe is 48v althogh I could be wrong. They are for a 3040cnc thanks for the help.
    Apr 2013
    1899
    Re: dq542ma power supply question
    I am sorry that nobody answered to you, perhaps it is too late since this is an old post, but here is my answer, perhaps it helps somebody else, if you are no longer interested.
    For the DQ542MA you only need one power supply and that depends on your motors. It can be used with a power supply up to 50V, so you really need to look at your motors first. I currently use my three DQ542MA drivers with 24V, but have also tested with 36V with my motors. I will in the end probably upgrade to 42V, but will not use the full 50V capability. I don't use any BOB, but yes, most of those demand 5V also. You can get that from the PC USB port or if you add a separate 5V supply if you need it. I use a USB interface, which does not need any external power, it drives the DQ542MA directly.
    Jun 2014
    8
    thanks for the help bud, I ended up just asking wantai and they recommended 2 36volt power supplies since I'm using 4 425oz stepper motors.thanks for the reply though.
    Oct 2021
    Have you solved the problem? Pls contact me at PM.
    Yaro, https://eduloh.com
    Nov 2021
    Ask here: https://programminggeeks.net/java-homework-help/
    They are good with technical tasks.
    Dec 2021
    Feb 2023
    For the bob and drivers, you will need a 5V power supply. For the motors, you will need a 48V power supply. You can find power supplies that are compatible with the 3040CNC online. Make sure you check the specifications of the power supplies to make sure they are compatible with your setup.
    If you need help with writing a term paper - visit my website https://rapidessay.com/write-my-term-paper.html
  1. Power Supply question
    By spectre03cobra in forum CNC Machine Related Electronics
    Last Post: 09-03-2010, 10:48 PM
  2. Power Supply Question
    By mcentric in forum Hobbycnc (Products)
    Last Post: 09-10-2009, 03:31 AM
  3. Power supply question
    By jhowelb in forum CNC Machine Related Electronics
    Last Post: 02-01-2008, 07:53 PM
  4. Power supply question, AC or DC?
    By Corruptor in forum CNC Machine Related Electronics
    Last Post: 02-26-2007, 08:54 PM
  5. Yet another power supply question!!
    By chas in forum CNC Machine Related Electronics
    Last Post: 09-17-2004, 05:49 AM
