585,663 active members*
3,020 visitors online*
    Apr 2013
    34
    Unhappy Fagor CNC Running single block once
    I am using Fagor CNC machine. Mode: 8040T
    Now if I run a program its run for one line each time.
    LIke:
    G00 X0 Z0.........................1
    G00 X-3 Z-4......................2
    G01 Z-5 Z-5.......................3
    G00 X0 Z5............................4
    If I press the cycle start it start to work line 1. Then stop. But in screen "In Execution" is still displaying..
    Then if press cycle stop, then reset, then cycle start again then run for line: 2. again stop..
    As far I know this behavior should be in single Block mode. But the machine is not in single block.
    Please help how can I solve the problem.
    Apr 2009
    13
    Re: Fagor CNC Running single block once
    Are you pressing single block button again before you execute?
    Mar 2008
    169
    Check following error when the machine are in execution. maybe you have to tune the servodrives.
    Carlos Cabrera
    Jul 2015
    Yeah sounds like your machine is hanging up trying to get to position. Following error probably your problem. Might be an encoder fault.
  1. stuck in single block
    By Tandem1 in forum Fanuc
    Last Post: 04-03-2020, 10:50 AM
  2. KmotionCNC single block
    By Dave3891 in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-28-2014, 03:19 AM
  3. single block G76
    By kjoy in forum G-Code Programing
    Last Post: 08-24-2012, 09:17 AM
  4. Single block keeps coming on
    By Technical Ted in forum Daewoo/Doosan
    Last Post: 12-15-2011, 05:47 AM
  5. Single block issues
    By MadPickinSkills in forum Machines running Mach Software
    Last Post: 01-05-2010, 10:16 PM
