I didn't see which probe you got, but its probably the one that uses 2 out of the 3 wires. If so, then its just like a limit switch that loses contact from multiple directions, x,y or z. Wire it up like a limit switch and assign the pins in mach3 for the probe. I wired a jack to the bob and mounted it to the side of the milling head. I also cut the cord and made it shorter, I only need it to mount in the spindle and connect by the side of the head, no need for a long extension that can get in the way.
Sent from my XT907 using Tapatalk
