585,712 active members*
3,881 visitors online*
    Aug 2013
    20
    Question LinuxCNC w/ Probotix Setup
    Hi yall,
    Does anyone know the proper setting in Stepconf for Probotix's stepper motors? The motors kind of hum/vibrate when being tested but don't actually move. Any help appreciated for this FNG! Thanks!
    My gear:
    ProboStep VX Uni-Polar Stepper Motor Driver
    (2x) HT23-280-8 280ozin Stepper Motor
    HT23-400-8 400ozin Stepper Motor
    PBX-2 Parallel Port Breakout Board
    Mar 2004
    1661
    Re: LinuxCNC w/ Probotix Setup
    Have you checked with Probotix? They've got some examples on their wiki. LinuxCNC Configuration - PROBOTIX :: wiki
    Otherwise, join the Lcnc mailing list and ask.
    Aug 2013
    20
    Svenakela, I have tried the setting for the V90 on this wiki page. This was the setting Probotix has told me to try but I didn't have any luck. I'm starting to think it's something with my parallel port. I'm not sure how to check that this is working properly though, I'll have to find more information about checking it. Thanks for the response.
    Mar 2004
    1661
    Get another parallel board, they are cheap.
    Aug 2013
    20
    Ok, problem resolved. Turned out to be the settings on my parallel port were wrong. Motors are responding now. I have some bogus information in there for the threads because I haven't bought the ballscrews yet so that will need to be adjusted but the axis are jogging now in Linux. Thanks for the help svenakela.
  1. Help Please - Driver Setup - LinuxCNC
    By CNC pupil in forum LinuxCNC (formerly EMC2)
    Last Post: 09-08-2014, 12:37 AM
  2. Nothing moves in LinuxCNC, but in setup it works!?
    By airtruk in forum LinuxCNC (formerly EMC2)
    Last Post: 12-08-2013, 09:37 AM
  3. Setting up pwm signal for Spindle in Mach3 - copying setup from emc/linuxcnc.
    By craynerd in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2012, 08:00 AM
