585,933 active members*
3,922 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport EZPath SD No BMDC Desktop I have Disks, forgot what to load
    Sep 2006
    94
    Hello,
    I have another EZ Path SD with no BMDC Desktop.
    Been a little while since my last one No BMDC Desktop from 2006
    I still have all the disks but I have forgotten which ones I need to load.
    Can not find a B3T.exe file though.
    Any help is appreciated.
    H. Howard
    Nov 2004
    3028
    Re: Bridgeport EZPath SD No BMDC Desktop I have Disks, forgot what to load
    This means the BMDC did not load. Because you have the S version, I know it has a Control in a box with a half size all in one mother board. This may have a daughter board for mass memory, or a disk on a chip, or if updated a Disk on a module. the mother board talks to the BMDC via the back plane. So, here are the possibilities. corrupted memory so you need to reload the software (I usually nuke it and start from scratch but for nuking you need to know what you have. A disk on a chip or a daughter board requires special software).. or bad memory so disable the disk on a chip and get a disk on a module. Could be communication, so pull the mother board and the BMDC and clean the edge connector on both with a soft eraser. Re seat and try. Worst case is that the BMDC is bad. I should mention that I have had issues with the logic power supply in the Romi CIB machines. it has very poor regulation.
    Machintek
    Sep 2006
    94
    Thanks Machintek,
    I have the disk on chip version.
    Removed the mother and bmdc boards and cleaned the contacts.
    Also moved the bmdc to another slot.
    Voltage is 5.1, 12.08, -11.9, and 24.18.
    BMDC still not loading.
    I still have the disks pictured here: Bridgeport Disks
    Could use a refresher on how to wipe and reload software.
    H. Howard
  1. Bridgeport Romi EZ Path S No BMDC
    By hrhoward in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2021, 06:28 AM
  2. BMDC error, desktop? = $1100 ezpath bill
    By i_r_machinist in forum Bridgeport / Romi Lathes
    Last Post: 06-11-2012, 01:14 PM
  3. Bridgeport eztrak bmdc
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2010, 09:10 PM
  4. Need help with a Bridgeport BMDC issue...
    By ralph@nes in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2007, 03:30 PM
